L520 engine swap
From fremont ca
im in fremont california about 45 miles out of san francisco and my engine code is j it was origionally a 1300 but when i got it it had a 1500 j series with a 5 inch hole in the block no joke it was pretty much square too but anyway my friend has 2 510s ones wrecked and hes giving me the motor which is a 1600 and tranny for around 200 and were pretty sure were gunna have to do sum coustom motor mounts and if anyone has any info that would help me thatd be great
Posted on: 2006/11/11 3:11
Re: L520 engine swap
OK, the first trick to learn here is to use the 'reply' button in the top right of each post & this overcomes the need to start a new thread for each reply.
Don't worry, we all learned by doing at the start & you will quickly learn all the tricks.
The simplest way to do this [not necessarily the easiest] is to find a junker 520 that originally came with an L series & use those parts that you need to make it all a bolt-in job. The hard part might be in finding the junker.
Google 'Datsun 520' & see what turns up. There is also a 'search' panel on the left side of this screen. Type 'Datsun 520' in there as we have dealt with these models before. At the bottom of each group of links, you may see 'show all replies' Clicking on this will give you access to all of the links. Patience is a virtue, so cruise around in there for a while & you will soon get the hang of it.
Good luck & welcome to the club.
P.S. Don't forget to add your basic location details to your profile so that they remain visible every time you make a post.
Posted on: 2006/11/11 3:34
Love your Datsun.
Treat it well.
From fremont ca
does anyone kno what the difference is between the j series engine bay and the l series engine bay im hoping it mite just be the motor mounts does anyone out there have this info
Posted on: 2006/11/12 12:59
From Vic Bendigo
i never thought the 520 or the 521 utes came out with l serise motor i thought they were j thats what i had in mine but you never know. i put and old pintara motor in mine(2liter)
Posted on: 2006/11/12 15:18
From fremont ca
just reposting to see if anyone knowsd where i can find a j 1300/1500 or how to do an engine swap for a 1.6 ive been searching the junkl years and ebay and craigslist and i still have yet to find anything
Posted on: 2006/11/24 3:26
From Perth W.A
the difference will be the mounts, you will have to make up new ones the J series is like a chunky a series so the fitting should be okay might just have to keep the engine low for clearance, get out a tape measure and run it around the engine bay see how much room you have and then from there see how big the L series motor is, and then get to work, you will probably have to fit a clutch master cylinder but other than that most other parts will adapt, or find an A15 and put that in it would probably be easier to fit and then fit twin webers or SU's
Posted on: 2006/11/24 6:38
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
