turbo 1200 setup please help!
hello i'm new to the site and me and my mate are setting up a turbo on our 1200 ute. the turbo i am using is a td04 of a wrx and it's the first time i've come across a water cooled turbo. my question is should i just tap into the heater hose or is there another option?
Posted on: 2006/12/26 7:12
Re: turbo 1200 setup please help!
From Fort Worth, Texas, USA
That is what I'm planning. I have one turbo from a twin turbo Mitsubishi 3000GT on a 1300 cc A-12 (A-12 block with A-14 pistons). I've teed the lines going to and from the heater core to flow through the bearing section of said turbo. Haven't run it yet so I don't know if it is going to work. Perhaps you could blow yours up first and let me know?
Posted on: 2006/12/27 15:20
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From campbelltown (sydney) australia
yeah itll be ok, just tap into the heater one at back of head, through turbo thern back into radiator hose, thats how i had it on my a15 turbo works fine.
Posted on: 2006/12/27 23:51
* caution, sunglasses must be worn to view my ca18det *
From brisbane
Kegs - did you notice much of an increase in the coolant temp after doing this?
Matty
Posted on: 2006/12/28 0:57
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
nope seemed to be pretty much same. what you can do is instead of using the nissan banjo fittings, isjust get brass tails they have same thread heaps better ....
Posted on: 2006/12/28 3:07
From Melbourne,Australia
Yeah it will be fine if you plumb it up through the heater hoses mines the same and i havent had a problem with cooling
Posted on: 2006/12/28 5:35
well we're in the middle of making the j pipe rite now. but the only thing that was worrying about was if tapping into the heater hoses it might varie in water flow or even might reverse flow if the heater was switched on?
Posted on: 2006/12/28 7:10
