rack and pinion steering?????
From Toowoomba, australia
i was just looking at how i could adapt an escort rack and pinion for the 1200 has any body ever thought about or tryed to do with or without sucess. i just think it would be interesting.
thanx DAVE
Posted on: 2003/2/13 12:44
why go up and down when you can go round and round
Re: rack and pinion steering?????
From Wanganui, New Zealand
I am doing that with the new coupe I am building up. I won't be using an escort rack...it will probably be Toyota or even Morris Minor. The Morris rack is very high geared, cheap and strong and has been used a lot for transplants into race cars.
Posted on: 2003/2/13 18:56
From Wellington New Zealand
Yep, my 1200 circuit car ran very short escort struts and rack. the rack goes in front of the xmember, so with a 12 inch engine setback you can drop the donk down quite low completely behind the rack without snarling your steering arms.
I cut the standard rubber mounting points off the rack and welded solid mounts on. All the suspension arms were fabricated up out of chromemoly, I used hi misalignment rosejoints instead of the standard balljoints. worked a treat, weighed nothing and with capri vented disks stopped like you wouldnt believe!
Posted on: 2003/2/13 21:31
ok cool. also do you think u could adapt the stanza struts to suit R&P steering? by swaping the struts to the opp. sides which will also put the brakes at the front which supposedly is better than having them at the back. or am i just living in a make believe land
thanx
DAVE
Posted on: 2003/2/14 0:46
Swapping the struts will work, and if your concerned about weight look for a rack out of a Fiat 124/125 as they are the same size/ ratio and are alloy for even greater weight saving.
Posted on: 2003/2/14 3:40
Great idea on the fiat rack. I ran the ford struts swapped left/right to work with the datto steering box before I converted to the rack.
Fiats also have a nice little steering column with two u joints in it which are bloody usefull to get the rack and the steering wheel connected!
Posted on: 2003/2/14 4:23
From Melbourne, Australia
could you do the fiat rack onto datsun struts?
that would be damn good i reckon!
same stud pattern and stuff
escort rack would be good as quick rack are available and reasnobly priced
Posted on: 2003/2/14 7:30
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
are u sure they have the same stud pattern cos the 1200 has a 4x114.5 i think it's 114. sumtin anyway and i think the fiat is 4x98 or sumtin
DAVE
Posted on: 2003/2/14 14:12
I dunno if the Fiat balljoints etc would slip in the 1200 steering arms, I did have a tapered reamer made for a very similar purpose...
Yeah, the PCD is different, but if you aint swapping struts..... Also, the ford struts have heaps of room for re-drilling PCD if you did use them.
Posted on: 2003/2/16 21:45
