Newbie and some torque specs please
Not too shy to talk
Hallo guys,I'm new here. I'm from Cape Town, South Africa.
I'm in the process of transplanting a Japanese import A15 lump into a Mustard coluored Datsun 1200 GX (rod bearing spun).
I'd like to check the condition of the big end bearings before dropping the motor in.
Could anyone tell me the bigend torque specs on the A15 please?
Also - are the big end bolts the" normal" type or "stretch" bolts like in some modern German motors?
Thanx
Posted on: 2007/2/19 8:52
Re: Newbie and some torque specs please
Quite a regular
From Garsfontein Pretoria South Africa
Hallo Mustard!!!
Welcome,
Posted on: 2007/2/19 8:59
If The Road is Straight Make it Sideways
Not too shy to talk
Thanks Sakkie!
This is my first Datsun/Nissan project car - I used to race a MKII Golf in GTI Challenge.
I got a bit tired of understeer though - this time I'm planning a stripped out Datto on steroids for some tail-out action
Posted on: 2007/2/19 9:34
Quite a regular
MOst fun you can have!!!!!!
What do you have planned for the A 15???
I am running A 14 with the A15 crank wich gives me a Standard a 15 but with a bit more umFFF!!!!!!
Posted on: 2007/2/19 9:56
Not too shy to talk
Plans so far is:
1. 1400 pick-up /ute springs and IGS dampers at the back - I'm not sure what to use for the fronts (I used to run 550lbs front springs in the Golf) - suggestions?
2.1400 ute 5 spd Gearbox - rebuilt of course , with 1400 ute diff (Killarney's straight is only 800m long ,and the rest is twisty - so I won't be needing top end speed,but rather acceleration out of the corners
3.286 deg cam (Mastercams)
4.Gasflowed head,skimmed to 11.8:1 CR (we are allowed 102.6 octane fuel)
5.Branch manifold (Bosson exhausts) and minimal sound damping (we have a 100dB sound limit at the track)
6.Two 40mm side draught Webers
7.Golf MK III radiator,expansion bottle and slim line electric cooling fans X2
8. 7 row oil cooler and baffles welded into the sump to prevent oil surge.
9.I need suggestions for some BIG brakes too, but that can wait 'till last - the above is more than enough to do in a single year
Posted on: 2007/2/19 10:39
From SE Melbourne
Hey Mustard
TORQUE WRENCH SETTINGS
. . . . . . . . . . . . . . . . . . . . . . . . . Cylinder head bolts 74 Nm
. . . . . . . . . . . . . . . . . . . . . . . . Connecting rod nuts 37 Nm
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Flywheel bolts 88 Nm
. . . . . . . . . . . . . . . . . . . . . . Main bearing cap bolts 59 Nm
......................... Camshaft sprocket 47 Nm
. . . . . . . . . . . . . . . . . . . . . . Camshaft locating plate 8 Nm
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Sump bolts 6 Nm
........................... Oil strainer bolts 14 Nm
. . . . . . . . . . . . . . . . . . . . . Crankshaft pulley bolt 196 Nm
. . . . . . . . . . . . . . . . . . . . . Timing chain cover bolts 7 Nm
. . . . . . . . . . . . . . . . . . . . . . . Rocker pedestal bolts 25 Nm
. . . . . . . . . . . . . . . . . . . Valve rocker adjusting nut 22 Nm
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Sumpplug 29 Nm
All the bolts on the engine are normal type....too old skool for stretch bolts. So you can reuse them if you wish.
Posted on: 2007/2/19 21:41
Mildman, Datsunless
Not too shy to talk
Thank you Mildman, I appreciate the help!
One more thing if you don't mind: Is the big end journal size on the A15 the same as the A14? .
It's easy to get hold of the A14 stuff here - so I'm hoping that there is no real difference if I need parts .
Posted on: 2007/2/20 2:18
From SE Melbourne
Yes they are the same size....here at the dimensiosn of the A14/15 bearings etc..
CRANKSHAFT AND MAIN BEARINGS
........................ Number of main bearings 5
............... End thrust taken at No 3 main bearing
................. End thrust clearance 0.05-0.30 mm
Main bearing journal diameter .... 49.951-49.964 mm
Main bearing journal under-sizes . . 0.25,0.50,0.75 mm
. . . . . . . . . . . . Main bearing journal taper limit 0.03 mm
Main bearing journal out of round limit ...... 0.03 mm
Main bearing to journal clearance .... 0.026-0.100 mm
.................. Crankpin diameter 44.961 -44.974
Crankpin undersizes ........ 0.08,0.25,0.50,0.75 mm
. . . . . . . . . . . . . . . . . . . . . Crankpin taper limit .0.03 mm
. . . . . . . . . . . . . . . . Crankpin out of round limit 0.03 mm
............... Bearing type Replaceable steel backed
. . . . . . . . . . . . . . . Connecting rod end float 0.1-0.4 mm
....... Crankpin to bearing clearance 0.030-0.100 mm
......... Bearing undersizes 0.08,0.25,0.50,0.75 mm
Posted on: 2007/2/20 22:18
Mildman, Datsunless
For all practical intents & purposes, the A15 is simply an A14 with an extra 5mm of stroke.
All of the technical specs relating to the crank dimentions, [except stroke], rods, bore, oil system, cam & it's drive system,..... hell, everything except piston dimentions [lower crown, bigger bowl] should be the same as the A14.
Posted on: 2007/2/20 22:49
Love your Datsun.
Treat it well.
Not too shy to talk
Ah thanks guys - glad to see that Nissan builds their motors like VW does - sensibly, without changing specs much between differing versions of the same motor.
I stripped the sump off my import motor last night and it's as clean as a whistle inside - no ridge on top of the bores and minimal bearing wear.
I changed the big end bearing shells with some good ol' Aussie ACL ones just to be sure,as the poor thing is sure to have a tough life from now on
Posted on: 2007/2/21 8:59
