quarter vent windows loose
Not too shy to talk
From Perth, Western Australia
Hi all. I'm sure this is a common problem, but my quarter vent windows are a little loose to stay open at higher speeds (1200 ute) does any one know what the solution is for this? I was thinking of putting a bolt through where the top bracket rivet is, or looking in the door to see what is on the bottom of the bottom bracket. Ideas?
Thanks,
Matt
Posted on: 2007/3/13 10:14
Re: quarter vent windows loose
Do you mean "loose" in that they appear to close, but wind comes through anyways? That is common
Or loose in that it doesn't close all the way or flops a bit? That's not too common, I've never seen it, not on front doors at least. There is inside the door panel and adjustment nut. It tightens against a spring so i would start there (tighten it a bit).
Posted on: 2007/3/13 11:15
