couple of questions
From Rocky Queensland
just wondering where abouts the oil pressure gauge should be sitting on a ca18det. its currently sittin at around 60 driving normal then shoots up when on boost. when i drove it back from brisbane it was sitting at around 50..
and also. i get a grind sound when i back off.. can it be that cause it sits that low to the ground that the tailshaft is on such an angle it makes that sound... i dont think its in the diff. its got a fairly new centre in it..
any help would be great. thanks
Posted on: 2007/3/28 0:04
Re: couple of questions
From Bendigo, Victoria, Australia.
when you say 60 you mean 60psi? that seems enough to me...
it may have been a bit low because there isnt enough oil, check the dipstick to be sure. otherwise keep an eye on it and if it goes anylower then id say get the pump looked at.
as far as the noise it could be many number of things. you might need to be a bit more specific.
gearbox bearings, lack of gb oil, lack of diff oil...
Posted on: 2007/3/28 2:17
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
yeah psi... i think its alittle over full of oil at the moment. i just needed a ruff idea of what its sposed to be on.. its hard to check the gearbox under my ute. i might do it all this sunday and give it a full work over
Posted on: 2007/3/28 2:40
From brisbane
Hi Campo
When cold mine sits at 80psi at idle. When warm it sits at 40psi. Your oil pressure will rise with your revs but 60 psi when cruising at highway speeds sounds about right.
Where is the grinding sound coming from?
Matty
Posted on: 2007/3/28 3:38
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
alright that sounds good then... im pretty sure i fugured out where its coming from.. the tailshaft is on too big a lean and the uni joints are abit lose. its in the shop now going for blueplate. needs a couple of things. 3" blocks need to be replaced with 2".. few wires need tidying. a few oil leaks and small things. and needs a cover over the surge tank in the tray.. then it should all be legal and ready for a thrashing haha... thanks for your help boys
Posted on: 2007/3/30 19:25
also. how do you guys check the oil in your gearbox. my filler bolt in that close to the tunnel i can even unscrew it out the gearbox.. it will be a pain if you have to drop the box everytime you need to check the oil and things like that. any little tricks to get this done
Posted on: 2007/3/30 19:27
From Melbourne AUS
if you cant get to the filler plug you wont be able to check the level
maybe find out how much the gearbox takes, dump the oil out and fill it with the correct amount through the shifter hole..
Posted on: 2007/3/30 19:30
1973 B110 A12
anyone know how much the ca box takes?
thanks ange. i woulda dropped the box out before i thought of that haha
any other ideas welcome
Posted on: 2007/3/30 19:35
