#11 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/14 13:13
i just worked out, when it does play up the fuel level in the bowl of the carb does not drop. does that mean it is not a fuel supply problem?
#12 Re: 1200 ute dying??
Graemes50 Posted on: 2007/4/14 13:43
Since you say that you have had the carb. rebuilt, I'm guessing that it is not a fuel problem.
It sounds like you may have an electrical fault in the ignition primary circuit.
[sounds like your secondary/high tension side has been rebuilt]
Have a good look at the wires going to/from your ballast resistor and even the resistor itself.
Wriggle everthing while the engine is idling and see if there is a miss/cutout.
Can you describe what happens when it goes wrong, engine dead, still running, no guts or what?
Aways difficult to diagnose from a distance, but ....
#13 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/15 12:45
when it plays up it has no power and sometimes stalls if at idle. pulled the plugs out just after it played up and they were light brown, indicating a lean mixture?? they are normally a bit black when i check them.
#14 Re: 1200 ute dying??
Graemes50 Posted on: 2007/4/15 14:53
Tan is good, ideal mixture.
I still think it is electrickery
#15 Re: 1200 ute dying??
WhiteSedan Posted on: 2007/4/15 14:55
Have you got the anti-diesel solenoid hooked up?
#16 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/15 15:55
is that the little soleniod on the front corner of the carby nearest to the rocker cover, if so yes it is hooked up.
#17 Re: 1200 ute dying??
WhiteSedan Posted on: 2007/4/15 16:19
Sure is, to test it put the ignition on and unplug then plug it back together, should make a click sound if working ok.
#18 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/17 11:08
it is working. i had that disconnected once before and the car wouldn't idle. the car is going to a mechanic tomorrow, so hopefully he will fix it asap
#19 Re: 1200 ute dying??
dobby3103 Posted on: 2007/4/19 10:53
IT'S ALIVE. turns out i was the carby. 28/36 weber going on hopefully on the weekend. Thankyou everyone very much for your help.
« 1 (2)
