WTB Front Left Brake setup for Datsun 1000
The front left back plate holding the two cylinders is so badly rusted (as are the nuts) that the spanner won't even grip the bleed valve, can't even get the cylinders off. So if anyone has got spares (those who have done the brake conversion!!) please let me know. Cheers.
Oh and looking for seats as well. 1000 or 1200 fronts, 1000 rear seat (Datsun 4dr B10
Cheers Chris....
Posted on: 2007/5/30 11:58
Re: WTB Front Left Brake setup for Datsun 1000
From Adelaide, Australia
Ive got backing plates if 1200 jobbies fit.
Posted on: 2007/5/30 12:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Freo
if you don't find any local,
I could prolly find some here..
cheers, Mike
Posted on: 2007/5/30 12:02
From Newcastle (NSW)
I think I have a complete set. I'll check tomorrow. The 1200 drum brakes are the same as far as i know. The axles, wheel bearings and everything....now that I think about it, I would double check the backing plate bolt pattern if you wanna use them.
Posted on: 2007/5/30 12:11
Racecar spelled backwards is racecar!
From Adelaide. SA
PM sent
Posted on: 2007/5/30 12:49
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Perth
Got some here too if need be
Posted on: 2007/5/30 14:51
Bloody hell fellas, fantastic response!
I'll start with Adam first (gx1200). I'll try make the weekend but I'm a dishy so the weekends are flat out for me, then I got uni most the week. Make time I suppose. Shall give you a buzz ASAP Adam, cheers bud.
Hey dattoman, I'll be chasing you for a front kit soon, just gotta wash a few more plates : )
Regards Chris
Posted on: 2007/5/30 15:53
