Thermo fans
From Gold Coast
Im still organising the little bits and pieces for the CA converion and i am wondering what size/how many thermo fans i should run on a S13 radiator.. opics and ideas would be great guys..
Cheers Wardy
Posted on: 2007/6/30 4:50
Re: Thermo fans
From Melbourne AUS
i would say a pair of 10inch thermo's would be more than adequate, and fit nicely.
Posted on: 2007/6/30 8:26
1973 B110 A12
Re: Thermo fans
From SE Melbourne
12" low profile is what I'm planning to buy. SPAL are the best, but expensive $200 or so.
Posted on: 2007/6/30 8:39
Mildman, Datsunless
Re: Thermo fans
Quite a regular
From Adelaide
i got two davies craig 10inches on the back sucking threw with a simple relay running to a switch in the cabin (thermo's get power on acc then i can choose if i want them on manually) so i dont leave them on... i also have a pritty phat intercooler in front of my brand new cored CA rad and it does'nt go over 80 degree's
Posted on: 2007/6/30 10:49
Re: Thermo fans
From Adelaide
Mildman,s right the SPAL fans are great, they have the best flow of any of the other fans avalible. I have two on mine and they work great.
Posted on: 2007/7/1 1:15
Re: Thermo fans
From Melbourne, Australia
my brother rang me yesterday and said he got a 16 inch at supercheap for 80 bux
and prices went down to about 20 bux but hes not sure how small they were
think 60 for a 12 inch
Posted on: 2007/7/1 1:19
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Thermo fans
From Gold Coast
Thanks for the help guys.. i think ill go with the twin 10" jobs.. has anyone got any pics that they can post up of there setup??
Posted on: 2007/7/1 1:35
Re: Thermo fans
Quite a regular
From Adelaide
here yah go mang
Posted on: 2007/7/1 4:48
Re: Thermo fans
From brisbane
I have found here in Qld that two 10" fans are not enough when stuck in traffic. I am about to upgrade to a thicker radiator and twin 12's. The temperature gradually climbs with the fans unable to cool the water temperature.
It appears that CA120Y has a bigger radiator than the factory CA/SR radiator although I could be wrong.
My advice is to fit the largest diameter fans you can initially so don't need to pull everything apart again to redo it. The biggest you can comfortably fit are twin low profile 12's.
Hope this helps.
Matty
Posted on: 2007/7/1 21:52
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
