Browsing this Thread:
1 Anonymous Users
Re: 32/36 carby fitted to an A15 - Hesitation on take off |
Registered Users Contentmaster Usermaster
That's right. If the temperature outside is not very cold you don't have to close the choke completely. If it is warm outside you can even start (cold) engine w/o choke.
Are you certain that when the engine is warmed up, the choke cable is preventing it from idling? If that's the case, you need to check that the choke butterfly valve is opening fully -- straight up and down.
If you are not sure, disconnect/loosen the choke cable, manually open the butterfly and after a 'blip' of the accelerator see if it will idle down. If not check to see if the throttle linkage is going against the idle screw.
Did you change the ignition at the same time as the carb? Maybe the engine timing is off?
Posted on: 2007/7/10 6:10
