« 1 2 (3)
Re: changing a clutch
Don't forget to mention getting gearbox grease all over yourself.
Regarding marking the flywheel components, you might do that if you putting the used pressure plate back on. With a new plate, no worries. A-series flywheel is not externally balanced so no need to mark it. My Nissan factory manuals do not say to mark it.
Posted on: 2007/8/7 16:16
From SE Melbourne
I had my flywheel & pressure plate balanced when I had my flywheel lightened....but even then it still only fits one way.
I'd even be tempted to mark a new one - but with this new clutch aligning tool I've got you can clamp the pressure plate and clutch together in a single assembly - makes it a bit easier....
Posted on: 2007/8/7 16:22
Mildman, Datsunless
« 1 2 (3)
