catch can designs
gday i am having a catch can and overflow tank welded up as we speak and one thing that needs to be decided upon is a cap for both? my question is for those who have custom catch cans what have they done for caps? and also the block breather pipe as it is 23-25 mm diameter what sort of hose/line did people use? any suggestions/pics would be very helpful
cheers, blake
Posted on: 2007/8/26 11:26
Re: catch can designs
From Gold Coast Australia
I really like this cap it is neat and tidy and has a custom made look to it. Included in the pack is the cap and also the threaded part that you just weld to the bottle.
Radiator overflow bottle and oil catch can
Radiator overflow bottle cap
Posted on: 2007/8/26 14:42
SR20DET Sunny for sale, click me for details
thats the same thing im after, do you have any more details........ are you saying you bought the cap and weld on thread? or did it come with the catch can? any details would be great
Posted on: 2007/8/26 22:31
Yeah, I got the cap and the threaded part, from rocket industries (the advertise in the front of street machine magazine) and then made the can up from a piece of aluminium pipe and two flat pieces for the top and bottom.
If you go to your local autobarn or supercheap and ask to have a look through their Rocket catalogue, you should see the different types of caps they offer.
Posted on: 2007/8/27 0:22
From sydney
I have needed one on the RS are these cheap ebay ones any good?
Posted on: 2007/8/27 5:57
i just had a look on the rocket industries website found the "weld in oil caps" pn:BS24110 now it says that they are alloy, can alloy be welded to aluminium?
Posted on: 2007/8/27 8:32
I am not a metal worker or anything but I am almost positive they are the same thing. The cap on my can is welded to alluminium plate, so I will say yes they can be welded together. Mine is TIG welded.
Posted on: 2007/8/27 10:15
wicked thankyou for your help in the matter bad310, now to answer sidedraughts question, i would get one with a breather (filter) or just drill holes in the top so that you are not sealing up the engine etc therefore over time the pressure in the crankcase wont build up
Posted on: 2007/8/27 10:18
From Wellington New Zealand
Yes you can weld them, in this instance "alloy" means aluminium.
Posted on: 2007/8/27 10:19
1200 coupe 1400 GX 5 speed
1200 coupe LHD peripheral port 12A rotary.
1200 ute
Sunny 310 SGX.
