brake fade
From W.A.
Hi all, got my car tuned up after a month of breaking in the engine. took it for a squirt and after two hard brakings they stoped working . when they cooled they were all right.
Is it worth spend $160 on EBS pads or should i get better disks? I think i have 180b disks brakes, should these have good brake capabilties for hill climbs and sprints?
thanks
Posted on: 2007/9/18 12:58
Re: bake fade
From Adelaide, Australia
You shouldnt have a problem with 180b brakes if they are in good condition. What sort of pads are in there now and how worn? How fresh is your brake fluid?
Posted on: 2007/9/18 13:01
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: bake fade
From W.A.
the pads are old so need replacing but the fluid is only 2 months old
Posted on: 2007/9/18 13:08
Re: bake fade
From Perth WA
Hey Jeff, your finaly on the Forums! Its Chris from Nannatee Way.
I would say the EBC's would be a good investment if you are gonna get stuck into hill climbs etc.
I just have ####ty RDA's in the thou and have never gotten brake fade yet
Posted on: 2007/9/18 13:12
Chris...
Re: bake fade
From W.A.
hey chris should catch up want to show you they new a14 it goes sweet!!
if the 180b disk should be up for it then i will get the ebc's.
Posted on: 2007/9/18 13:16
Re: bake fade
Dont replace pads and discs at the same time, do the pads and then a month down the track the discs.
Posted on: 2007/9/18 13:17
IPRA Build
Re: brake fade
From Perth W.A
drop in and see dattoman1000 he will be able to ggive you the 411 on the best direction
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
Re: brake fade
From Perth WA
Jeff, Ill race you in the thou! Thats on the road now(dont think it was when u saw it last). Swing by one time (if the 1000 and the blue 720 are out the front i should be home)
Posted on: 2007/9/18 13:20
Chris...
Re: brake fade
From W.A.
is dattoman local.
Posted on: 2007/9/18 13:22
Re: brake fade
From Perth WA
Kelmscott way, Bit of a hike from up here. Shoot him a PM or call him at work. Race Brakes WA: 93900183
Posted on: 2007/9/18 13:42
Chris...
