Advice on 120Y strut insert options.....
From Bris-Vegas
Starting work on the 1st stage of my front suspension upgrade this w'end.
Going to try cut down Gemini coils as suggested.
The 120Y struts are staying at stock length & ride height (for the time being)
Can anyone suggest a good quality shock insert?
A part or model no. would be $hit hot.
Thanks in advance,
Coops
Posted on: 2007/9/19 4:44
CA18DET '74 1200 ute project
Re: Advice on 120Y strut insert options.....
From Perth W.A
KYB 362001 fronts
Posted on: 2007/9/19 6:12
120y Coupe
120Y coupe Race car (SOON)
120Y Sedan for the Lady
From The garage, NZ
are they shorter than standard? and does anyone know if 120y and b110 shocks are same length standard
Posted on: 2007/9/19 7:27
From Perth W.A
that part number is a standard replacment shock from KYB. not sure on 1200 interchangability
Posted on: 2007/9/19 7:36
120y Coupe
From Bris-Vegas
Thanks for that.
I was just thinking I probably should be doing rear shockies at the same time.......
You don't by any chance have the KYB part no for 1200 ute rear shocks?
Posted on: 2007/9/19 9:34
