Torque settings for engine rebuild
Hey,
Whats the best torque settings to use when rebuilding an A12.
Mine has 10.5 comp, balanced, relieved pistons .75mm over.
cheers
dazzzzler
Posted on: 2003/4/9 7:12
Re: Torque settings for engine rebuild
Higher clamping force on the head is better ... but I believe the limiting factor is mainly in the design strength of the head bolts.
Here are the factory specs for head bolt torque:
A12 early 33-36 ft-lbs
A12 late 40-43
A13 51-54
A14 51-54
Posted on: 2003/4/9 21:40
thanks ddgonzal
would you have the rest of the torque settings as well
cheeers
dazzler
Posted on: 2003/4/12 13:46
dazzler, take a look at the Tech Section article Changing Head Gaskets
Posted on: 2003/4/12 19:20
