wheels for 1200
Not too shy to talk
From Lisboa, Portugal
does anyone know if a set of Cobra TC Supaslot 6X13x31 offset will fit an original datsun 1200? they have 4 holes but are they ok for datsun??? I mean they were fit to a Cobra TC, i had the ideia they should fit an original datsun, but not sure, hope someone can help me on this one!
Thanks!
Posted on: 2003/4/17 15:31
Re: wheels for 1200
What's a Cobra TC?
The Datsun uses 4 on 4.5 inch bolt center. There is of course a metric conversion for that, but the original spec is 4.5 inches, same as other Datsun RWD, Toyota RWD and 1960s Ford.
Most 13s will fit with the stock 1200 brakes just fine, depending on the offset [fwd wheels usually fit the back, but not the front] ... maybe someone can measure the stock offset for the original 4-inch wide wheels and post it here.
Posted on: 2003/4/17 21:45
Re: wheels for 1200
From Warwick, QLD
Yeah if as DD said that if your stud pattern matches, then it should be alright. Offset I find is something you don't really have to worry about as they have so many things out there to help with you fitting wheels. If the offset is too much of a positive value ie.+40(meaning your wheels will sit in more, as the mounting surface is further away from the center of the Rim)
Alls you need is spacers, they bring the wheel out more. If the wheels are less of a positive value they like +25 they will sit out more, which alls you need is a mate to help roll guards if you even need to do it, or put on some flares, in my opinion flares make a car look real mean (but depending on car, those SLR torana's looked bloody terrible with flares)
Cheers
Damo
Posted on: 2003/4/18 4:06
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Re: wheels for 1200
Not too shy to talk
....cobra tc....my mistake, it's simple the wheel model
i saw a escort mk2 and a vauxhall chevette using those wheels, so they might fit the datsun
Posted on: 2003/4/18 11:50
Re: wheels for 1200
The US Chevette and the German Escort/Capri II use a different bolt pattern than Datsuns.
The same aftermarket wheel model is usually offered in different bolt patterns ... so TC might have the Cobra in 4.5 and 4.25 and 100mm patterns.
Posted on: 2003/4/18 22:40
Re: wheels for 1200
From Melbourne, Australia
anyone seen, in life or pics, skyline 15" rims on a 1200, the white 5-spoke ones off the R31 i think
i think they are 4-stud?
and maybe fit without spacers or anything???
Posted on: 2003/4/19 12:03
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
