(1) 2 3 »
help with e15et in 1000ute
From Adelaide, Australia
i couldnt find much on this subject but i have put a 120y gearbox on to my e15et by using a vanette thrust bearing and carrier (little smaler in length) ive used the stock e15 flywheel and clutch and all looks to match up perfect. next i recon i have to dril a round hole in my fire wall to fit my dizzy. does anybody know if i will run into any other probs? i think i may also have to cut my utes engine mounts off :(. also does anybody know if a turbo off a
ca18 will fit straight on to my e15et manifold?
Posted on: 2007/10/14 11:55
Re: help with e15et in 1000ute
From Perth WA
somebody put a thread up called 'food for thought' or something about fitting a E15(FWD) into a A series(RWD) engine bay. Looks like your gonna have alot of trouble with engine mounts! Have a search for the thread.
Good luck! and keep us posted!
Posted on: 2007/10/14 12:40
Chris...
as long as theres a thread around ill hold it up lol
Posted on: 2007/10/14 12:58
From Adelaide. SA
Tnpshow started the thread on this. A CA turbo should bolt up to the standard manifold.
Cheers
Posted on: 2007/10/17 1:08
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
From Adelaide, SA
Here it is
Might have to pull the finger out and chuck it in the wiki...
Posted on: 2007/10/17 1:24
. what oil cooler? hopefully i will be droping this motor in this weekend. hopefully? i thk the fctory computer will be easy to wire up. i got the wiring diagrams of www.n12turbo.com
any i deas where to get a turbocharger of a ca or sr. a T25 i think in adelaide? oh yea does anybody know if i can use a e15 non turbo electronic dizzy on the et model?
Posted on: 2007/10/18 13:12
hey guys just havin another prob. my bonnet wont shut by 2-3 inches. how can i get the e15 to fit under the 1000 bonnet? can i lower the crossmember? will it effect my steering ect?
Posted on: 2007/10/22 11:23
From Perth WA
Haha yeh thats the biggest drama with 1000 engine conversions. Height! You may have to go XR8 bonnet hump style! Or a scoop of some description. Doubt you could drop the X member, maybe a 10mm spacer?
Posted on: 2007/10/22 12:06
Chris...
does anybody know if there is a tailshaft the same as my 1000 one but 2-4 inches longer?also again does anybody know if drop my crosmember 1-2 inches if it will effect anything else such as steering and suspension. if not i may have to modify sump, rockercover and bonnet. i really really dont wanna put a scoop or anything on it
Posted on: 2007/10/23 11:51
From ACT
could you not tilt the engine towards the passenger side slighty? should make it low enough, plus give more room for things like a brake booster
Posted on: 2007/10/23 11:59
(1) 2 3 »
