B310 coupe zx part info
From The garage, NZ
Hey guys
The B310 came out with a coil sprung rear end which leads me to my question on what differential nugget it came with?
Info on the rear end assembly is appreciated as there isnt much on the b310 at all in the wiki.
Cheers
Posted on: 2007/10/25 9:23
Re: B310 coupe zx part info
From Adelaide, Australia
H150 matey which is directly interchangeable with a H165 Stanza (A10) rear axle. The centres dont interchange but the whole assembly does.
You can use the H150 centre in a H145 housing with a 2mm spacer to space the centre out so axles align. Also will have to use a late 120y (later 120ys have H150's) or sunny tailshaft.
Posted on: 2007/10/25 9:38
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From The garage, NZ
cheers dude.
Actually just looking for info as am looking at a sunny with an a15 and 5 speed and it has a noisey diff prob from being thrashed but just wanted to know what i could get one from.
That solves everything though.
Thanks
Posted on: 2007/10/25 9:45
From The garage, NZ
also how much bigger is a b310 coupe to a 1200 ?
Posted on: 2007/10/25 10:31
I'd have to check my manual later tonight, its it a bit of difference, when I used to own my stanza (same floorpan) it was huge in comparison especially on the inside.
Posted on: 2007/10/25 10:38
IPRA Build
From Gold Coast Australia
I have only been in 1200 utes and a coupe, but my Sunny's have all been so much roomier inside.
Another plus is the engine bay is about 50mm wider between the strut towers (give or take a bit), so if in the future an engine conversion is on the cards the bigger bay means it will be a bit easier getting around the bigger motor.
Posted on: 2007/10/25 15:02
SR20DET Sunny for sale, click me for details
A lot. The engine compartment is about 2 inches wider.
Posted on: 2007/10/25 22:35
