« 1 (2)
Re: r31 handbrake set-up
From Everywhere, mostly Melb/Geelong/Ballarat
*smacks self in head*, ahhhh bump stops, thanks BAD310 . Off to Repco for me.
Posted on: 2007/10/29 20:42
From Bris-Vegas
Or do what I did.......
Place the too small bump stops on top of the axle housing.
Set the u-bolts up loose.
And..... Torque those little ba$tards down .
And guess what.... The H165 bump stops now fit the R31 axle.
It's like an old fitter I used to work with always used to say...... "A good tradesman knows when to be rough"
Posted on: 2007/10/29 21:50
CA18DET '74 1200 ute project
From Western Sydney
Hey guys,
did you weld mounts for the gas shocks to mount to?
also, where can i get the u bolts to fit around the diff, as no one at local parts store no wats going on!
cheers
Posted on: 2007/10/30 10:40
From Nyngan, nsw Australia
short-coupe wrote:
only difference my brackets where underneath.
I was think the same thing underneath the diff better idea.....
By putting it on top means you have to relocal the fuel tank, don't want to do that if i can help it.......
Posted on: 2008/2/17 8:17
wonder how maddat is getting on with the h/brake cable for the R31 diff
Posted on: 2008/2/22 10:35
« 1 (2)
