need A12A connecting rods
Not too shy to talk
I am in need of some A12A connecting rods if anyone knows of where i can get them i would appreciate it thanks
Posted on: 2008/1/5 2:38
Re: need A12A connecting rods
Have you tried Nissan? Part number 12100-H8500. They are listed in the latest catalog (meaning they *might* still be available).
Posted on: 2008/1/5 5:01
Not too shy to talk
yea i checked and the people i called said no but if you could check in a dealer near you and see what they say i would appreciate it
Posted on: 2008/1/5 22:59
All the dealers across the USA have access to the entire inventory. So it won't help to check another.
Unless you didn't have the part number. Sometimes they won't bother to look it up. If you didn't give them the part number, call another dealer and ask.
Posted on: 2008/1/5 23:02
From Vancouver WA. U.S.A.
Are they different from a A12 if not i have a set
Posted on: 2008/1/6 3:47
BE sure to check out my coupe build thread and feel free to leave comments good or bad.
[url=http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=36107&fo
Yes, they are different.
The A12A uses a 75mm bore size & these pistons use the larger pin in common with the A14 & A15 models, The A12A is based on the short deck block, so the rod is the same length as the 1200 & A12 models, but with more 'meat' at the little end & a bigger pin hole.
This rod has the same dimensions as the short stroke A13 engine which differs only with its 76mm bore.
Posted on: 2008/1/6 4:31
Love your Datsun.
Treat it well.
