Need help finding a replacement carb.
From North Dakota, US
Hi, I was wondering what are some common alternatives to use instead of the original A12 carbs. We have a Hitachi I believe and we've gone through hell and back with two different carbs using the best of both and numerous carb rebuild kits and nothing we do seems to fix it. We just can't get it to run right and even when we do, it screws itself up after awhile and starts running like crap again. I'd like to have some twin Webers but the cheapest I've found them is $600 and we only paid $300 for the car and are trying to do the cheapest rebuild we can. We've got all new parts for the drivetrain that we need but none of them will matter if we can't get a decent carb on it. What have some of you guys used in place of the originals? And where do I find one for a decent price? Thanks
Posted on: 2008/1/27 18:21
Re: Need help finding a replacement carb.
From Portugal
A good replacemente is a Weber dgv 32/36...they are cheap, around 50$...at least that what mine cost...and you'll need an adaptor plate...get it off ebay or build one...
Search around ther is a lot of info on it...i have one...and your car shouldnt run like crap on a stock carb...take a look ate the ignition sistem...check your advance...my stock carb ran like crap and when i started looking for the problem i saw the distributor was all the way back with max retarded advance...
hope i was helpfull...peace...
Posted on: 2008/1/27 19:03
Datsun 310GX(FWD) and 120Y(RWD)...drive straight or drive sideways...
Weber DGV is the most common replacement. See http://wiki.datsun1200.com
Although for economy and smoothness, a rebuilt Hitachi is the best.
Posted on: 2008/1/27 20:13
From Bendigo, Victoria, Australia.
hey pennyjunk. you have a pm.
Posted on: 2008/1/27 22:03
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From Perth WA
As stated above check your ign system first! Because when you think about it. a A12 with a original A12 carby should run beautifuly as if it came out of the factory. unless there is something wrong.
How is it running poorly? Bad idle? Missfiring? Lack of power/revability?
Posted on: 2008/1/27 22:52
Chris...
The major problem is the idle. It runs pretty rough and fast, it wont keep running at a low idle, and the choke doesnt seem to work very well
Posted on: 2008/1/27 23:54
1973 A12s have a fuel cutoff solenoid. If this is not wired, or not working, the engine won't idle below about 1200 rpm. Details here: Datsun1200.com wiki - anti-diesel valve
You can usually find a rebuilt Hitachi or Weber DGV (32/36) on eBay any given week.
Posted on: 2008/1/28 1:00
