Lightened camshaft & flywheel ?
From Seattle ,WA.
I took these a while back, the cams are marked as follows;
Lightened one - DE 84 & 5754
Standard cam - 16, M & 180
Can anyone tell me anything about these, they look almost identical except one looks like it's been cut down on a lathe.
Here are the two flywheels, the clutch disc is the same size but the pressure plate is different. Any ideas how to identify the plate needed if I want to run this one?
Thanks all.
I'm also feeling like a genius right now, I just finally figured out how to insert an image into the post
Posted on: 2008/1/28 5:47
Re: Lightened camshaft & flywheel ?
The relatively flat flywheel for for RWD A-series.
The flywheel with recessed "step" for clutch disk may be from a Datsun F10 (FWD Datsun).
Posted on: 2008/1/28 5:52
From Seattle ,WA.
So if I bought this I could take it apart & check it huh!
I'm curious if it'd be an advantage to try using the lighter one or it would matter much at all.
Any thought's on the cam's?
Posted on: 2008/1/28 5:56
From Castro Valley,CA USA
I was going to say that the cam has just been reground, but that sure looks like a lot of material removed for a regrind.
Posted on: 2008/1/28 6:29
