« 1 (2)
Re: R30 Skyline stumpy gearbox info
From Nyngan, nsw Australia
gx1200 wrote:
MR30 skylines (early 80s) which are 6 cylinder have the stumpy 5 speed. Pintara's were never made then. the Pintara the your refering to is the R31.
Hope this clarifies it for you.
Adam.
ok ......so r31 pintara i should be looking out for!!!!Quote:
Posted on: 2008/1/31 5:16
From brisbane, qld
No, you shouldnt be looking for a pintara. The pintara came with a ca20( read boat anchor) and the gearbox is the only thing really worth using.
Dont stuff around, just buy a motor and gearbox out of a silvia and be done with it. This is what you want by the sounds of things, its the only place you will get a ca18 or sr20 rwd set up in australia, and if you want to use the standard datsun shifter hole and handbrake position, buy the stumpy box and use the bell housing from the silvia box on the stumpy.
Posted on: 2008/1/31 6:32
If it is still not clear, do a search. This topic has been covered many times.
Posted on: 2008/1/31 9:10
From brisbane, qld
AMEN!
Posted on: 2008/1/31 10:15
CLEAR
Posted on: 2008/1/31 22:36
From The garage, NZ
i always thought they came behind l20et's?
Posted on: 2008/2/1 4:55
sorry justin yes i mean CA20,.....
chris... that l20det is that aussie or import at your end (NZ),
from pintara's or what !!??
Posted on: 2008/2/1 5:18
« 1 (2)
