Ca18det coil question...
From Radelaide, South Australia
hi All,
Getting very close with the ute...
just wondering, i was going to get splitfire coil packs but only because i dont have any coil packs at all,
so i have decided to go and get just normal coil's and mount them on the firewall, like the one's in this ute...
Do i need to use resistor coils or just any coil...
i understand the wiring side of them but thought i would ask, Any help would be great... cheers...
Dane...
Posted on: 2008/2/3 9:47
Boost.. boost.. BOOST!!! Gotta love Lag...
* 76 coupe, twin 40mm a12, project...
* 79 ute ca18det, track/street...
* 84 FJ45 landcruiser project...
* 88 D21 navara 4x4, sr20de vvt daily...
Re: Ca18det coil question...
From Warwick, QLD
Coils aren't always as simple as you think. You have to get the ones suited to your setup and ECU, some coils require resistors some have built in dwell controllers which for the likes of microtechs etc they don't work with them. I would go with the Bosch HEC715 I beilieve they are.
Have a quick look into them as it may save you some headaches down the track.
Cheers
Damian
Posted on: 2008/2/3 9:54
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
Thanks mate, yea i thought there was a tad more involved... im planning on using the standard ecu..
Posted on: 2008/2/3 9:57
