I need front brakes & a front bar
From Melbourne ( West )
Im after brakes for my 1200 ute,
Wouldn't mind a set of 280zx front...
Also after a front bar too!
Anyone in Melbourne know of any of these items please let me know.
Thanks...
Sam.
Posted on: 2008/2/2 1:53
Re: I need front brakes & a front bar
From Melbourne AUS
ive got a pair of front standard 1200 ute struts with drum brakes that you can have for free.
but if your after discs i also have a pair of stanza struts with slotted discs, calipers, new wheel bearings, new brake pads and new flexible brake lines.
and if you dont need the whole setup ive also got a pair of rebuilt stanza calipers and a pair of stanza standard discs.
ive also got a black front bar, no mounts.
in melbourne also.
Posted on: 2008/2/2 5:16
1973 B110 A12
From Northeast USA
Pardon my ignorance, but what U.S model is the same as the Stanza?
Posted on: 2008/2/2 6:14
- Gerry -
The Stanza meant is the 1978-1982 Datsun A10 -- called in USA "Datsun 510" and most other places "Datsun Stanza".
In USA the newer fwd models are called Stanza, but the A10 was the last rwd model.
Posted on: 2008/2/2 6:44
Thanks for your reply...
Are stanza front disks vented??
How much are you after for them? and where in melbourne are you?
Will an engineer pass a CA18det ute with those brakes you think? (just moved to Victoria and I don't know what they're like down here).
Is that your green ute? If so, what's in it?
20 Questions!!!
Sam.
Posted on: 2008/2/2 10:28
From Melbourne AUS
stanza brakes are not vented.
im after $200 for the stanza struts/brakes
im in the western suburbs
stanza brakes will pass with a ca1200.
my green ute has a 12a rotary which passed engineering with the actual brakes im selling.
remember, legally you can only travel 110kmh on victorian roads. so your brakes have to be able to stop the weight of your car from that speed safely. no matter if you have 100kw or 1000kw.
give me a ring if your keen on the struts
0403227449
Andrew
Posted on: 2008/2/3 11:40
1973 B110 A12
From Western Sydney
FYI - DBA have slotted rotors for stanza's, i think i paid $250 ish for both front...
Posted on: 2008/2/4 6:08
From Melbourne AUS
yes your right. the slotted discs on the struts im selling are dba's.
Posted on: 2008/2/4 6:44
1973 B110 A12
