Lowering the B210?
From Selah, Washington
1200 strut tops will get me 1 1/2" of drop?
Or do I use more than the tops? I have a pair of 1200 struts. I do want to maintain some rigidity.
Giddy Up
Posted on: 2008/2/13 6:45
Re: Lowering the B210?
From Adelaide, Australia
Im pretty sure the strut is the same length (they use the same inserts) and just the strut top lowers the car, as for 1 1/2 inches im pretty sure it would be about and inch at the most.
Yee hah!
Sorry it is 1 1/2 inches; cable-tie image -
Posted on: 2008/2/13 7:19
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
The 1 1/2 inches is what I found on here by Brocky41 on his 120y
Clicky
Posted on: 2008/2/13 7:22
Yeah sorry you were correct!
Posted on: 2008/2/13 7:25
IPRA Build
Where is the bearing in each of those? Exactly the same place? Or lower in the B110 hat and higher in the B210 hat? That will make a difference.
Disc-brake B210s use at least two different strut sizes. Are the inserts really the same physical size?
- Australia B210s have small diameter struts (45 mm, same an B110)
- USA B210s use the larger diameters struts (50.8 mm large Datsun size)
Strut Inserts.
But apparently the hats interchange.
I have new in the box inserts for both sets of struts B210 and the B110 also
Ebay cheap
I collect shtuff for no apparent reason
Heavy on the "sh"
Posted on: 2008/2/13 7:33
Can you measure both and post here? Most outside diameter of the inserts, but length, stroke and shaft diameter will be useful as well. Thanks in advance.
Posted on: 2008/2/13 7:49
Sure no problem. I will also provide part #'s if legible
Posted on: 2008/2/13 7:50
From Springwood NSW, Formerly Tas.
thats awesome
Posted on: 2008/2/13 7:53
1978 120y Coupe.
Im pretty sure it was the later model B210 (74+ or 76+??) that went up to the larger diameter strut tube, balljoints got the larger bolt size and pattern as well as getting the matching lower control arms and steering arms.
Posted on: 2008/2/13 8:00
IPRA Build
