Carby and fuel preasure questions
From Adelaide. SA
Just questioning if a "facet" type fuel pump will be enough to run a sidedraught carb on an A series motor? If it is suitable do I need to run a fuel preasure regulator?? and also what preasure should it be running at?
I hope someone can help.
Cheers. Adam.
Posted on: 2008/2/25 2:19
It's not for the money and its not for the applause!
"Live life, follow your dreams",
Peter Brock
Re: Carby and fuel preasure questions
From Brisbane, Narangba
Most Facet pumps are rated to around 200hp. They run around 3-5psi which is ideal for carbs so no real need for a regulator. I use one to run twin 1 3/4 (45mm) Su's no worries.
Posted on: 2008/2/25 2:41
From Adelaide. SA
Does that apply to webbers too??
Posted on: 2008/2/25 2:46
Peter Brock
From gold coast QLD.
Adam,I run a small facet pump on the KB10 and is feeding a single 45 sidie on an oval port manifold,no regulator,no problems with too much pressure or float lift or needle and seat issues to date.
Cheers
Robert
Posted on: 2008/2/25 3:10
From Adelaide. SA
Thats exactly what I wanted to know! how did you get a manifold for the single sidie?? Im thinking of making one.
Cheers. Adam.
Posted on: 2008/2/25 3:47
Peter Brock
The manifold is a highly modified round port,with an extra plate tig'd onto the face,then machined out to match the inlet ports and smoothed out as best we could internally.
It absolutely runs rings around the poxey 32/36 down draft,and no bonnet issues in the KB10,it's even giving reasonable fuel consumption and is easier to drive with great flexability
Posted on: 2008/2/25 6:32
From Melbourne AUS
why not run the standard mechanical pump?
Posted on: 2008/2/25 6:55
1973 B110 A12
All my standard pumps Of the required type required kits thru them to operate 100% and when you have electric ones lying around and dirt cheap compared to re kitting old ones it's an easy descission to make.
Cheers
Posted on: 2008/2/25 7:06
