Red 13B Coupe, Minnesota USA
eBay Item Number: 200188304161
Datsun 1200 fastback with rotary 13b freshly rebuilt engine rotors are off of a turbo2 with atkins 2mm apex seals, peripheral port with Holley 950 cfm carb. 3" exaust with an 4" cherry bomb turbo II transmission with Racingbeat racing clutch ford 9" rear end with 514 gear ratio and full spool w/ 31 splines NOS big shot system with blue holley fuel pump willwood rear disc brake system, dual MSD 6AL. with 2 step 15x10 rear draglite with 26x10 tires also will include an extra pair of 28x11.5 drag slicks the car has enough room to fit 30x13" tires w/o any modifications competition engineering ladder bar suspension system w/ afco adjuatable rear shocks
Posted on: 2007/12/31 7:23
Re: Red 13B Coupe, Minnesota USA
Still for sale?
eBay result: $5,250.00 Reserve not met
Posted on: 2008/3/3 5:11
Yes, still for sale: http://minneapolis.craigslist.org/car/580871080.html
72 Datsun 1200 fastback - $13000
Date: 2008-02-20, 4:01PM CST
This is a datsun 1200 the car has a mazda 13b peripheral.It also has a holly 950cfm brand new it right out of the box tow msd 6al and to holly fuel pumps one is red and the other one is blue.the trans is a turbo2 rx7 the motor is build with turbo2 rx7 rotors so if you want to put a turbo in it you can.The car diff is a 9in ford whith ladder bar setup.The car has alot of partl to list.
if you are interested call only serious inquiries.Think call ... John or Elias
Posted on: 2008/3/10 5:38
