what about working the engine then?
From Perth WA
So if working on the engine, go a cam, extractors, and port and polish? What would you need to get to 120-130hp?
Posted on: 2003/5/20 15:03
Re: what about working the engine then?
From melbourne aust
depends on what engine you have maybe on an a15 but on anything smaller youd need better carbies or injection maybe high compression pistons
Posted on: 2003/5/20 16:12
From Perth WA
Its on an A14 with a single webber,
what sort of dollars to get it to 120hp?
Posted on: 2003/5/21 3:58
From Charlotte NC USA
you will need to find some compression and a bit of a cam the carbies are a good idea as the weber down draft is a bit small for the revs you will need to turn in order to make the power you want
Posted on: 2003/5/21 11:48
Phil (aka nutcase)
I have C.L.W.E.A.
Can't Leave Well Enough Alone
120y exelant clone gone :(
Yes, Weber DCOEs or other side draft setup is what you want. The Weber 32/36 can do well over 120hp, but the stock manifold used with the 32/36 isn't good for high flow. With sidedrafts, you'll get a high-flow intake manifold to match.
Posted on: 2003/5/21 22:43
From Perth WA
Weber DCOEs? im not a pro with this kinda stuff, where would i get one of those from and what would it cost?
Posted on: 2003/5/22 16:13
see the "Which Carburetor?" link on the home page about 1/2 way down.
Posted on: 2003/5/23 23:46
