Browsing this Thread:
1 Anonymous Users
71 datsun 1200 ute questions??? |
did they come from factory with reverse lights???
and if yes where is the wires that connect to the gearbox???
the wires i think are near the lights but i cant see any that go from body to the box...
did the early 70 and 71 come out with a month/year or just year on id tag???
because its so old the id tag only shows the engraved engine and body number the rest of the details are worn away from age the rta says aslong as the body number is vissible it dont matter has any1 else had this before and what did you do as i just put stickers to show the model year etc so if they wanted to check underneath they can peal off
would this be ok???
if some1 with a pre 71 model can answer these questions and tell me any differences between the early 70 models to the 80 models it would be much appreciated so far i been told on pre 71 no hazzards no retractable belts mph dash no compliance plate metal grill no side mirrors
Posted on: 2008/3/9 4:00
Re: 71 datsun 1200 ute questions??? |
From gold coast aus
i guess it depends what state you are in but in nsw i was told 70 model is pre adr so there for dosnt need the adr plate with build date on it not sure on other states or your other questions my utes 84 my 1600 is 70 model just incase someone was wondering how i found out with 84 ute
Posted on: 2008/3/9 9:47
i thought so as my car only has the id plate but would like to know a few more things if any1 has a early 70s datsun i think the adr compliance plate come out in 72 but not 100% sure
Posted on: 2008/3/9 22:57
From gold coast aus
my 70 model 1600 had adr plate . but when i stripped it for rebuild i put it in a safe place so i wouldnt lose it. guess what. i lost it . when spoke to rta the told me that it was now pre adr so wouldnt need it . going of the taillights that are available for the utes you would say they had reverse lights . earlyer model datsun had them . so its were already usingthem then. the wires for reverse lights should only be 2 wires but and will be long enough to reach that spot . being that your car is 37 years old hard to say that someone hasnt modified it in some way over that time . ive had couple cars where reverse light switch is no good so they have been hooked up on toggle switch .
Posted on: 2008/3/9 23:11
Registered Users Contentmaster Usermaster
With the 1971 cars, the reverse light wires go from the engine compartment back to the transmission along the tunnel.
Can you see the chassis number? It should be stamped in the sheet metal of the firewall, just below the bonnet.
Posted on: 2008/3/10 1:59
From Bendigo, Victoria, Australia.
they're yellow i think from memory...
Posted on: 2008/3/10 10:13
"Like a Rolling Stone" Bob Dylan
New Daily: <<<<Now For Sale. 1972 B110, 13" Bathurst mags, airbrus
if reverse light wires went through tunnel from engine bay there deffinatley been chopped and there not there any more so ill have to run new wires from in the cab to box and back to lights
ddgonzal... yes the engine and chassis number is stamped in the plate on driver side and also in body above firewall but the rest of the details of the id plate are not there as there worn away only visible thing on plate is the engine.no. chassis.no.
i asked blueslip place and they said they can use the chassis number to find the details like build date make and model through the rta
so i guess i just have to go for rego and see what happens now
has any1 else had this problem and what was done to fix it???
thanks guys
Posted on: 2008/3/11 7:34
From newcastle nsw
i had a ute that i got for parts had no chassis engine plate o it only chassis number stamped into body called rta they saill all was fine as it had been regoed before they can look it up and will go thru rego no worries
Posted on: 2008/3/11 7:39
2 blueslip places and rta info line said same thing i dont have old rego papers only a receipt and rego ran out 6 years ago will it still be on the rta database??? i do still have the rego label on front window
Posted on: 2008/3/11 10:39
