Break booster leaking fluid Any ideas before i pull out???
i have a new master cylinder
new lines and fittings
it seems to be leaking either from or both
the plate that sits between master and booster i see fluid dripping from booster side of that plate
and the bottom bolt of the master cylinder
any ideas any1?????????????
any1 had this before??????????/
its a 120y booster/master cylinder setup
i noticed this when i was under the car and want to fix it but want a few ideas before i pull all appart cause its a pain in the ass
thanks
Posted on: 2008/3/23 1:12
Re: Break booster leaking fluid Any ideas before i pull out???
It's a bad master cylinder. Brand new, but it's leaking. Brake fluid doesn't run through the booster.
Posted on: 2008/3/23 1:16
so its imposible for a good master cylinder to leak from
the bolt
and that plate between the booster and master
if i explain whats happening to the break place i hope they will replace it for me if thats the case
what a pain in the ass you wouldnt think a new product would be faulty
NOT HAPPY
Posted on: 2008/3/23 1:23
If you have fluid coming fron the back of the master cylinder, regardless of what it's attached to, then as Ddgonzal said, the chances are that the brake [not break] master cylinder is faulty & that it is leaking fluid past the seal on the rearmost piston.
Damned unusual for a new one to do it. but is can happen.
If it's faulty, then they should replace it under the guarantee.
Posted on: 2008/3/23 5:51
Love your Datsun.
Treat it well.
From Launceston TAS
the plastic reservoir on my ute cylinder was hairline crack ; leaking fluid down fire wall. easy fixed though.
Posted on: 2008/3/23 8:19
it sure is brand new
i bought it from a local BRAKE place...lol...
how could a seal go on a new master cylinder???
i double checked and it comes out between the master cylinder(bottom) and the plate on booster
not looking forward to pulling out and bleeding all over again
is there any way i could have stuffed it when installing
i cant imagine many ways i could have stuffed it appart from being faulty from factory but i would have thought the chances of that are very low but my luck spose the odds are there
Posted on: 2008/3/23 8:20
i did notice the reservior clossest to back is lower then the front and when i installed they were the same im pretty sure
i checked the reserviors and cant find any leaks i was hoping it was that or the clamp loose or something but no luck with any leaks around there
Posted on: 2008/3/23 8:23
