« 1 (2)
Re: Electronic Ignition Wiring Question
I know that a Kettering [points type] ignition requires a condenser, & 2.2 microfarads seems to be a common capacity, but I don't recall seeing one on an electronic ignition before.
I run a Pertronix kit in my 1200 distributor & a factory HEI system on the L20B in my 200B & neither of these use a condenser if that's any guide.
Posted on: 2008/4/15 16:09
Love your Datsun.
Treat it well.
which terminal is which on the distributor??
It is T-shaped. There is the head of the T, and the stem of the T. Marked 'c' & 's' on the black box.
The wiki has the wiring for it:
Head of T: Blue or White wire (coil negative)
Sstem of T: B/W wire (coil positive)
Posted on: 2008/4/15 17:16
Thanks.
Posted on: 2008/4/15 18:59
« 1 (2)
