Clutch Cable Cover
From adelaide
what is the best way to get rid of the plate covering the hole for the clutch cable? i guess to drill it. but do i just drill the holes i need? or is there a way to remove the whole plate? its a 1200 sedan
Posted on: 2008/4/25 3:38
Re: Clutch Cable Cover
Find an auto with a blank plate or make one.
Posted on: 2008/4/25 3:39
From adelaide
i should have been more specific. ok, the sedan was auto, but have put the manual box in, and need to get rid of the plate that covers the holes in the fire wall for the clutch cable to attatch to the pedal. dunno how to go about it though?!
Posted on: 2008/4/25 3:42
Are you sticking with A series and cable clutch? If so you will need the correct plate with the sleeve for the cable adjustment.
Posted on: 2008/4/25 3:55
From adelaide
yeah A series, and standard cable. got all the parts i need, i pulled it from my wagon. just dont know how to get the plate off. if i just drill through the plate for the three holes i need, plus the oval hole and leave the rest of the plate on, will that extra couple of mm's matter?
Posted on: 2008/4/25 4:13
From Sydney
my plate was just bolted on(120y coupe)??? u sure ur looking at the right spot??
Posted on: 2008/4/25 6:00
From adelaide
yeah its the right spot
Posted on: 2008/4/25 7:48
From SE Melbourne
Does this help?
Posted on: 2008/4/25 7:56
Mildman, Datsunless
