(1) 2 3 »
Adjustable Camber Plates - Aluminium Design
From Melbourne, Australia
Nissan Datsun Camber Plates
Posted on: 2008/5/7 9:41
Re: Adjustable Camber Plates - Aluminium Design
From Gold Coast, Australia
ill be interested in a set in the next couple of weeks, so are they readily available?
Posted on: 2008/5/7 10:31
From Adelaide
as im using the 120y strut set up with s13 brakes, am i going to get much camber without change the control arms and all that?
if so, when these products ready o buy?
Posted on: 2008/5/7 11:10
Generally readily available. I've got a few sets ready at the moment.
If you are running standard LCA's, with the 120y struts, you should be able to get heaps of camber with these. Longer arms will just give you even more (that's not necessary!)
Cheers
Andy
Posted on: 2008/5/7 12:15
Still got a few sets ready to go
Posted on: 2008/5/13 13:16
From Finland
Hi,
Does the shipping offer also apply to overseas forum members? I might need a pair in the future after I have sorted numerous other things in my 120y.
-Matti
Posted on: 2008/5/13 16:19
From The garage, NZ
the picture of them trial fitted to the 1600.. is that with them set up centred?
Posted on: 2008/5/13 22:16
Not 100% sure about shipping OS. But if you are keen, l'll work something out (send me a PM with details, and l'll get back to you).
The "trial fitment" pics are more for ensuring the PCD into the chassis is correct, and also that the adjustment screws don't foul and allow enough movement.
There are 6 adjustment holes, and full length slot (plus the bottom plate can be rotated 180 degrees), so there is a large amount of movement (positive and negative camber) possible.
The picture is in a "rough" centre position, but heaps more negative is possible by moving those two bolts to the other end of the plate.
Cheers
Andy
Posted on: 2008/5/14 9:50
keen on a set... actually two but probably can only afford one
Posted on: 2008/5/14 11:51
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
No probs Michael. When you are ready, let me know!
Posted on: 2008/5/16 8:35
(1) 2 3 »
