Sunny diffs
Hi, Want to put a sunny diff into Morris Minor. What I would like to know is will other diff centres fit the Sunny housing. Thanks
Posted on: 2008/5/18 1:11
Re: Sunny diffs
From nowra nsw
the standerd center(h150) should be alright depending on how much power your motor has u can get lsd's for the sunny(h150) theres someone on this site that makes them cant remember for about $1200 brand new
Posted on: 2008/5/18 1:34
Re: Sunny diffs
Thanks for the reply. I am not familar with Datsuns. I will be using a mildly worked 1200 motor, makes it easy for rego, no engineers certificate needed. What models are the h150 centres in?
Posted on: 2008/5/18 2:20
Re: Sunny diffs
* B210 (1975-1978)
* B310 (1979-1982)
Posted on: 2008/5/18 4:08
Re: Sunny diffs
From sydney
What is wrong with the Sunny diff you have that makes you want to get a different centre?
Posted on: 2008/5/18 6:14
Re: Sunny diffs
Thanks for the reply. Original post may have been a bit vague. I don't want to get a different centre I just want to know what models used H150s as there is a good chance that I will be able to get a Sunny diff housing without the diff.
Earlier post said that H150s were in B210 and B310. I am now confused it seams the B210 was called the 120Y in Australia, was the B310 the same as the Sunny?
I supose what I really want to know is that if I get this housing, change it to fit under a Morris Minor there is a couple of models that used H150s so it should not be a big problem to get hold of one later.
PS Did other models apart from B210 and B310 use H150s ?
Posted on: 2008/5/18 8:52
Re: Sunny diffs
120Y: 1974-1978 120Y is a B210.
Sunny: 1979-1982 Sunny is a B310.
Whichever country you are in, it will say B210 or B310 on the engine compartment ID plate.
Not that we can think of.
Posted on: 2008/5/18 19:10
Re: Sunny diffs
From sydney
This diff is still in plentiful supply , as its difficult to get lower ratio gear sets for it, they have not all been cannibalised for racing cars.
Posted on: 2008/5/18 23:37
