Browsing this Thread:
1 Anonymous Users
floor pans |
From ACT
Hey guys still having trouble finding floor pans even from nissan, any ideas anyone???
Posted on: 2008/6/10 8:33
Re: floor pans |
From Broken Hill
Joey, as far as I know the only regs are that they dont allow any exhaust gases into the cab. I was planning on replacing with some pressed 1.6mm mild steel plate and miging them in, little massaging with a hammer, no one will see once the carpets in, overlapped on inside, full seam. How bad are yours, i only have one hole either side, passenger as big as a fist, and under throttle pedal pivot about 30mm.
Posted on: 2008/6/10 13:45
Re: floor pans |
if you were in the states, I have some for sale in good shape
Posted on: 2008/6/10 21:52
Re: floor pans |
From ACT
hey duncs7t6, My holes are in the same spot around the acc pedal and where the drain hole is in the pans, also along the trans tunnel where the old gearbox mounts used to be.
So you recon if i try to plate up those sections and mig them it should be alright????
Posted on: 2008/6/11 11:00
Re: floor pans |
From Broken Hill
Joey, Im looking into it, plate thickness, donar cars, rare spares etc. I will PM you, see how I go.
Posted on: 2008/6/16 8:55
