Ute wire color for Temp Sender
Any one with a RHD ute, can you look and tell me the color of wire connected to the temperature sender on the front of cylinder head?
My new 1200 truck has the wire disconnected (and worse, has a newer wiring harness in it with a zillion wires). I can't figure out which wire it should be.
thanks in advance
Posted on: 2008/7/6 7:04
Re: Ute wire color for Temp Sender
From Adelaide
Mine is a 12/84 B120 and it has a Yellow wire with a spade connector for the temp. sender.
There is also another Yellow taped to it but it has a female bullet connector.
NFI about that one
Posted on: 2008/7/6 8:11
Nissanman - just trying to help...
From Tamworth , NSW
my 81 model is yellow/thin white trace, and bullet connector.
i didnt see the trace till i looked a bit closer.
Posted on: 2008/7/6 8:29
Thanks. I have a yellow bullet, it is (apparently) the oil pressure light switch. I will look for a yellow spade.
Posted on: 2008/7/6 8:35
