Browsing this Thread:
1 Anonymous Users
wiring questions?? |
From young
Hi all i finally got my dash fixed up and put back in but have a few problems, 1. as soon as i hook the batrery up 2 red warning lights come on and they stay on all the time even when the key is out of the ignition, this wasnt like that when i bought the utean anybody tell me what ive done wrong please??. 2.i put my cd player in and wired it up the same way as the old cd player was but it turns on when the key is on the lock position then off when its in the off position and back on again when the key is on accesories, has anybody else had the problem of it turning on when the key is on lock?? and is there a way to stop it so that its only on when the key is on accesories or on?? again this wasnt like this when i bought the ute any help would bbe very much appreciated THANKS Appsy1
Posted on: 2008/7/20 4:22
1200ute jelly bean mags twin 40mm dellortos
Re: wiring questions?? |
Registered Users Contentmaster Usermaster
If you had the gauge cluster out of the dash, be sure that when it is replaced that is grounded (earthed). There is a screw at the bottom that grounds the cluster to the dash frame. Without that weird problems with the lights occur.
There are probably other things that cause this too.
Posted on: 2008/7/20 4:41
From young
ok thanks where abouts is the wire on the back of the cluster i had a look today and cant see one THANKS Appsy1
Posted on: 2008/7/22 4:40
There is no earth wire. There is a single screw. Make sure it is securely tightened to the dash frame.
Posted on: 2008/7/22 5:40
