Clutch cable interchange
Which clutch cables interchange with Datsun 1200?
As I understand:
* 1970-1973 transmission has a smaller cable hole
* 1974-up transmissions have larger hole
* B210, B310 use the same cable
So two basic cables. Is that right?
Do any FWD datsun cables fit? We have clutch cables here from fwd Stanza, Sentra/Sunny, etc.
What is the length of a stock 1200 cable?
Posted on: 2008/7/20 5:33
Re: Clutch cable interchange
From Brisbane
both cables are the same length (800mm), they are identicle except for the aluminium end that slips into the gearbox.
Posted on: 2008/7/20 6:44
thanks, an old post said the newer ones are 1 inch diameter where it goes into the gearbox housing.
Posted on: 2008/7/20 6:50
From Brisbane
the larger of the two cables is 25mm and the other is about 18mm
Posted on: 2008/7/20 7:01
