rear bushes
hi im in need of a little help i carnt get the rear bushes for the front spring mount the part that bolts onto the chassis there is 4 per side i have heard of people making them out of steel can this be done?
Posted on: 2008/8/14 12:47
Re: rear bushes
From Melbourne, Australia
or you could just buy em from a local parts store
Posted on: 2008/8/14 12:48
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: rear bushes
i have tried they only can get there rear ones which are different
Posted on: 2008/8/14 12:51
Re: rear bushes
From Yass
Mad dat have these and so does GSA wholesale suspension. good prices as well.
Posted on: 2008/8/14 13:05
Re: rear bushes
From Tamworth , NSW
on a ute?(just realised your name is madcoupe!), autobarn stock the front ones and the rear ones, only thin i found was that you need to get 2 sets of fronts because the 2 sets on the rear are 2 different sizes. one of them will be the same size as the front ones, but you will need to cut the ends off them as they are a wee bit too long.
Re: rear bushes
thanks but its for a coupe not a ute they have a thicker bolt in the front than the back hence y i carnt get them ill try made dat tho i machined up a steel one just before and it dosnt look to bad but i dont no if it would work fit ok tho
Posted on: 2008/8/14 13:09
