« 1 (2)
Re: Datsun 1200
Quite a regular
From melbourne
oh ok kool ... looking good tough some seriouse mechanical skills put into her..
great job!!
Posted on: 2008/8/25 12:31
Re: Datsun 1200
wat comp and turbo you gonna run and expected pwr??
Posted on: 2008/8/25 12:32
Car free
Re: Datsun 1200
This whole running gear setup has already been running in another car..... it runs a 1.06 3540 and autronic computer. 30 psi boost on 33% toluene mix made 430 rwkw with a manual, and 380 with an auto.
Posted on: 2008/8/25 13:03
Re: Datsun 1200
From SE Melbourne
Holy crap that is alot of power! 430rwkw!!!! I assume it is being built as a drag weapon?
Posted on: 2008/8/25 13:28
Mildman, Datsunless
Re: Datsun 1200
Yea pretty much and street
Posted on: 2008/8/26 12:02
Re: Datsun 1200
Quite a regular
From melbourne
thats insane!
Did you mod like a 180sx crossmember in or just the 1200 one? what brakes you running ? converting to 5 stud?
Posted on: 2008/8/26 23:12
Re: Datsun 1200
Its the standard 1200 crossmember, it has been cut and plated to be 20 mm lower so the engine can sit lower. The brakes i use are the datsport kit with r33 calipers and discs.
It is still 4 stud. I might go 5 stud but i have to get another set of r33 discs redrilled as they bolt behind the hub differently then the gazelle hub i use now.
cheers
Posted on: 2008/8/27 9:39
Re: Datsun 1200
From perth
what diff you gonna use?
hilux or 9"
i dont think a b/w will cope
dazza
Posted on: 2008/10/18 12:49
« 1 (2)
