Does anyone in Perth have a carbalancer??
From Perth
Does anyone here in Perth have a Carbalancer??? Its for balancing multiple carbies. I need to use one to balance the injection setup. The front and rear cyls are backfiring. Just wanna tune them to make sure they are recieving the right air.
Posted on: 2008/8/26 11:11
Re: Does anyone in Perth have a carbalancer??
From Adelaide, Australia
I just bought one a couple months back, a must have, before that I would use a large peice of rubber hose and you can hear the difference as the air rushes in and get it somewhere handy.
Posted on: 2008/8/26 11:29
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Perth
yeh had one for me last 1200 with twin su's thought since i used quad throtts, I wouldnt need one. but since i only got problems with the front and back pistons its an air problem
Posted on: 2008/8/26 13:54
From Adelaide
Try using one of these.
It does need a connection to the inlet runner but it is very sensitive and won't interfere with the air flow to that runner like a Unisyn does.
They aren't very expensive so you might want to get a pair so you can read the vacuum pulled on a good cylinder compared to the bad ones.
Posted on: 2008/8/27 4:11
Nissanman - just trying to help...
From Perth
Try using one of these. It does need a connection to the inlet runner but it is very sensitive and won't interfere with the air flow to that runner like a Unisyn does. They aren't very expensive so you might want to get a pair so you can read the vacuum pulled on a good cylinder compared to the bad ones.
Yeh where to find???
Posted on: 2008/8/27 14:16
From Freo
I have one..
Carbs are where it's at...lol
Posted on: 2008/8/27 14:18
A15 PSI Project Motor
'72 CB750k,
From Perth
come on dude. injection is fun ey! Mind if I come over with the beast and use it for a sec??
Howd u go with the SU's??
Posted on: 2008/8/27 14:24
From Adelaide
On eBay but most Auto Stores will have this or something similar.
Posted on: 2008/8/28 0:39
