what master cylinder
From Wagga Wagga, NSW
When i finally get my 120y struts in, am i going to need a new master cylinder? Or is there something i can do to mine? Ive been reading it i wiki, but i get kinda confused. I read that i can get a disc brake mater cylinder or i can remove some valve in mine.. Id rather keep the one ive got. Just put a kit through it
Help?
Posted on: 2008/9/23 16:22
Re: what master cylinder
The 'valve' that requires removal is located behind the feral that seals the brake pipe. It is easy enough to do if you have done it before but it is very easy to damage the feral if your not careful. It does not pay to ignore the advice in the wiki as if you don't remove the "bleedback valve' the front brakes will not be able to release without interferance and can cause lockups and brake bind.
Posted on: 2008/9/23 21:45
Alright then. Anyone have a disc brake master cylinder?
Posted on: 2008/9/24 1:54
I think im in the same boat any chance of a diagram?
Posted on: 2008/9/24 9:20
I'll be converting my master for disc brake rear. If it all pans out without destroying it I'll take some pics and post them.
Posted on: 2008/9/24 9:35
