Weber 32/36
From Perth
Anyone had luck in getting a weber 32/36 to work right (without any lag or flat spots). I just can't seem to get the carby set right on my 1500. I have tried a few combinations of jets and visited lots of threads but nobody has posted a YES IT WORKS & HERE ARE THE JETS YOU NEED thread. The best combo I have yet is, fuel 140-140, air 145-145, emuls F50-F50 and idle 50-50. Any help would be great.
Posted on: 2008/9/25 7:26
Glen
Morris Minor, Datsun 1500, Supercharged, 5 speed.
Re: Weber 32/36
From Monroe, wa, usa
try a 60 in the primary progression jet. Every Datsun I've used these on has a lean spot there. If you set your idle at 1700rpm and adjust the idle mixture until it runs smooth, you'll know where you need to go on the progression jets.
Posted on: 2008/9/25 14:42
NAPA parts bitch
