wat sort of diff is best for a datto ute
From cairns
hey guys im just wonderin is it best to be putting a coupe diff in a datto ute or wat would be another way to go want to get better ratio
Posted on: 2008/10/26 9:24
Re: wat sort of diff is best for a datto ute
From bathurst nsw
coupe and sedan diffs are smaller, if you want more acceleration try a c20 vannette the one with the A12 in it 4.875, or if u want a 3.7 ratio try a series 2 bluebird
Posted on: 2008/10/26 9:29
My car gets me from A to B...Just faster ;)
From Melbourne AUS
stanza's have a 3.9 H165 centre which is pretty common.
Posted on: 2008/10/26 9:31
1973 B110 A12
From newcastle, NSW
depends on what you intendn to use the ute for? in my opinion if you are going to stick with the A-series engine the stock ute diff is a good little unit, i had one in my coupe that had a CA18det in it and it handled the power pretty well.
If you want better highway driving you mightwant to consider a bluebird diff centre. From memory the H165 from a bluebird bolts straight into the ute housing.
Posted on: 2008/10/26 9:59
