Megasquirt Question
From Lisboa-Portugal
If i buy an assembled megasquirt box do i still need the stimulator, to run with a Hyundai Efi setup?
Posted on: 2008/11/1 16:46
Re: Megasquirt Question
No, it is not needed. The Stimulator is used to test a Megasquirt board. If you buy one already assembled, it should have been already tested and working correctly.
Why not just use the Hyundai EFI sensors and controller?
Posted on: 2008/11/1 20:51
Do you think is better DD? I plan to use the sensors and injectors of the Hyundai efi with the megasquirt ECU so i can adjust the way i want it, and i don`t know if that`s possible with the standard Hyundai ECU.
Posted on: 2008/11/2 15:55
You cannot adjust the Hyundai EFI. It simply runs good. With MegaSquirt, it runs bad mostly until tuned.
Posted on: 2008/11/2 17:15
So is better i spend my money in the hyundai ecu and intake to put it in my A12. I thought megasquirt was better!
Posted on: 2008/11/2 18:00
No one has tried it.
Posted on: 2008/11/2 18:31
From Melbourne, Australia
people have tried megasquirt with good results
the hyundai ecu will run the car well without having to play around with it
but if you want to play and learn to tune a car and do further modifications to the engine later then megasquirt would be better to try to get the most out of it
Posted on: 2008/11/2 21:19
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Ok you convince me and there always the possibility of using those ECU Remap Flash tools. Has anyone tried galleto tool?
Posted on: 2008/11/3 9:42
