« 1 (2) 3 4 »
Re: 1200 X-member
From newcastle, NSW
Posted on: 2008/11/16 10:17
Re: 1200 X-member
From Nyngan, nsw Australia
your clever thanks
Posted on: 2008/11/16 10:19
living is good,.....
Re: 1200 X-member
From newcastle, NSW
i'd be worried about it moving! i made an adjustable x-member in my coupe, but i just drilled another hole 25mm away from the existing hole, worke quite well under race conditions.
Posted on: 2008/11/16 10:21
Re: 1200 X-member
stevo have alookc in photo album, you'll see it in there
Posted on: 2008/11/16 10:35
Re: 1200 X-member
From Adelaide
Thats definately not factory, look at the spoggy welds. If that is just reliying on the control arm bolt to stop it moving, i would not be trusting it.
If the bolt had camed washers, it would be a bit better.
Posted on: 2008/11/16 10:36
Re: 1200 X-member
my uncle has owned it since new and never had any suspension work done whats so ever
Posted on: 2008/11/16 10:40
Re: 1200 X-member
From Adelaide
AH thats what i was talking about, that looks like the same camber bolts that was uses on 90's model Falcons.
Re: 1200 X-member
yes whats why ive never seen on 1200 before till now
Posted on: 2008/11/16 10:42
Re: 1200 X-member
From newcastle, NSW
oh ok i see what u mean. how much adjustment does it allow?
Posted on: 2008/11/16 10:43
Re: 1200 X-member
From Adelaide
Must be a rare option, i have worked on hundreds of 1200 x-members and never seen that before.
Posted on: 2008/11/16 10:44
« 1 (2) 3 4 »
