« 1 2 (3) 4 »
Re: 1200 X-member
From Nyngan, nsw Australia
sssute wrote: look at the spoggy welds.
yes not a very good weld........i could better with my eyes closed
Posted on: 2008/11/16 10:44
living is good,.....
Re: 1200 X-member
From newcastle, NSW
a mate of mine bought an adjustable rearend for a 1600 from Maddat(when craig had it) it uses the same lobe principal for adjusting the rear end
Posted on: 2008/11/16 10:47
Re: 1200 X-member
From The garage, NZ
that cant be factory
Posted on: 2008/11/16 10:48
Re: 1200 X-member
sssute
i email you a few weeks back you were saying there was a bit of a shortage with 1200 x-members,not enough customers sending theres to ya,
you were asking me to send mine to do it instead,
i was to send it to you for a ca18det mod change should be ok for you to do
Posted on: 2008/11/16 10:50
Re: 1200 X-member
From Melbourne, Australia
thats definately not stock and is definately designed to be used with camber bolts
it would be dangerous to use that without camber bolts
Posted on: 2008/11/16 10:52
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 1200 X-member
hotrocket wrote:
my uncle has owned it since new and never had any suspension work done whats so ever
I suspect that either your uncle suffers from fuzzy memory or it was done in conjunction with some other work & he never knew.
It's just part of an aftermarket camber kit & I recently fitted one in my 1200 coupe. I also installed one in my 1200 Ute many years ago.
The bolt has two eccentric washers [one each side of the crossmember] that are keyed to the bolt. [see picture in an earlier post] The diameter of the washers fits neatly between the turned out ends of the part that is welded to the crossmember.
The original bush in the lower arm has 'teeth' on the ends of the inner sleeve so that the bolt must be loosened for aligning, then turned for adjustment. When this is correct the nut on the bolt is tightened after the vehicle is bearing its own weight on the front wheels,
The 'teeth' then dig into the crossmember & anchor the central sleeve to the crossmember preventing both rotation & lateral movement. The eccentric washers are now locked in position helping to prevent lateral movement also.
No rocket science here, just a readily available aftermarket kit, but that car has definately had front end work done at some time & it was possibly done after [or during] some accident repair work.
The range of adjustment is not great as it was intended to allow correction of minor alignment problems as a result of minor accident damage or from a crook vehicle build. If the misalignment required more adjustment than these could provide then the car needed to be on a chassis aligner & fixed properly.
Posted on: 2008/11/16 10:53
Love your Datsun.
Treat it well.
Re: 1200 X-member
From Adelaide
Spot on Dodgeman.
Yea Rod you can send your x-member, and i'll mod. it powdercoat and send back.
Posted on: 2008/11/16 10:59
Re: 1200 X-member
Dodgeman wrote:
I suspect that either your uncle suffers from fuzzy memory or it was done before the Ute was sold new. [Most unlikely]
The bolt has two eccentric washers [one each side of the crossmember] that are keyed to the bolt. The diameter of the washers fits neatly between the turned out ends of the part that is welded to the crossmember.
The original bush in the lower arm has 'teeth on the ends of the inner sleeve so that th bolt is loosened, then turned for adjustment. When this is correct the nut on the bolt is tightened after the vehicle is bearing its own weight on the front wheels,
The 'teeth' then dig into th crossmember & anchor the central sleeve to the crossmember preventing both rotation & lateral movement. The eccentric washers are now locked in position helping to prevent lateral movement also.
No rocket science here but that car has had front end work done at some time & it was possibly done after [or during] some accident repair work.
Dodgeman ......you have done your home work......but i asure you no damage nor suspension work done.....uncle only 43 hehe
never gave me any prob's before pulling down
Posted on: 2008/11/16 11:02
Re: 1200 X-member
it will be one of those mysterys,....
and cheers scott send off soon as abit more funds come my way
Posted on: 2008/11/16 11:07
Re: 1200 X-member
Well it's not a factory fitment & it didn't sneak up in the middle of the night & install itself, so somebody put it there.
Posted on: 2008/11/16 11:13
Love your Datsun.
Treat it well.
« 1 2 (3) 4 »
