« 1 (2) 3 »
Re: Car uses coolant but not water?
From Adelaide, Australia
It isn't 'spose' to run coolant either.
Just make a overflow bottle from one of your empty coolant bottles, put hole in lid for hose, put hole in lid for air and don't let hose bottom out in bottle and it will work.
Posted on: 2008/11/18 8:05
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Bendigo
well it has a nissan motor company anti freeze sticker in the engine bay that looks very old. So I rekn it is Spose to have coolant
Posted on: 2008/11/18 8:10
From Melbourne, Australia
Car ARE 'spose' to run coolant it raises the boiling point of water and also helps fight corrosion in the engines water jackets as water by its self corrodes these over time.
Im stumped why your car spits out cooland but likes water its a mystery let us know what you find out as i fell everything said on this thread is correct advise to help you out
Posted on: 2008/11/18 8:37
I never said coolant shouldn't be used, I just stated that from factory these cars didn't have coolant as we know it with both anti-freeze and rust inhibiting properties.
I think you'll find back in the 70's you just used distilled water and rust inhibitor.
So why not just put a overflow bottle on, mark where it's filled to, drive to work, let it cool, see if level is lower, if so your loosing it elsewhere.
And a coolant can be a liquid as long as it aids in the transfer of heat, ie using oil with a cutting tool.
Posted on: 2008/11/18 8:47
IPRA Build
I agree with you WhiteSedan, a overflow bottle is the way to go.....
And when you say "isnt spose to use coolant" I think that a pretty straight foward comment dont you?
And who is saying a coolant cant be a liquid???
In my book in order to cool you need liquid...... hence oil and water
Posted on: 2008/11/18 9:02
Your car is allergic to crap coolant! Be sure to use the correct cap if you decide to run a recovery system. There are 2 types. Recovery and Non Recovery.
Posted on: 2008/11/18 9:06
I just think not wanting to put an overflow bottle on because it's not meant to have one is funny, and the only reason not to would have to be originality and I was just stating that these cars 'In my eyes' only ran distilled water and rust inhibitor so that wouldn't be original also.
Posted on: 2008/11/18 9:14
IPRA Build
Okay im not trying to pick a fight here i understand what your saying and were your coming from now.
I agree with what you say put in a overflow bottle and change the cap to a recovery cap and see if its loosing water. if so you have a leak.
Im curious to hear what the out come to this issue is
Posted on: 2008/11/18 9:26
I thourght distilled water was used only to top up batteries with??????
Did they use it in cooling systems???
Posted on: 2008/11/18 9:29
Not too shy to talk
From Greece Athens
I think DatJaffa is rigt. I also put an overflow without changing my radiator and it works properly.
Posted on: 2008/11/18 9:32
« 1 (2) 3 »
