A12 Specs Needed !!!
From Mandurah WA
Well i just aquired myself a full A12 Engine today for a good price, nothing :)
(assuming its a12 came from a Datsun 1200 Coupe)
All i got it for is a project for school rebuild a engine so this will be perfect.
Now what i need is some specs on the engine..I looked at the tech section but that doesnt give me much of a help :)
What im after is torque specs for the:
Head -
Manifolds
Big End Bearing Caps
Main Bearing Caps
Aswell as ingnition timing / dwell settings. Valve gap, Spark plug gaps aswell.
And if anyone is from Perth WA im after a stock carby for the A12.
Im sure one of you datto lover can help me out
Cheers
Posted on: 2003/7/12 9:29
Re: A12 Specs Needed !!!
From GOLD COAST AUZ
HEAD 53LB 72nm
MANIFOLD 10LB 13nm
BIG END 27LB 36nm
MAIN 42LB 58nm
ING 7 to 8 deg
DWELL49 TO 55deg
VALVE 0.25mm cold
SPARK 0.8 to 0.9mm
dizzy rotation anti-clockwise
FIRING ODER 1-3-4-2
bye my book
Posted on: 2003/7/13 12:24
rather be a old fart than a young d##khead
From Mandurah WA
Thanks heaps !!!!
Thats exactally what i needed
So both the inlet and exhaust valves are 25mm ?
Posted on: 2003/7/13 12:33
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
From GOLD COAST AUZ
My racer is set at 0.8 in 0.10 out but that is only for short racing havent done along one yet
0.25 is the book
Posted on: 2003/7/13 12:45
From Auckland N.Z
buy the 1200 manual it cost me $15 and its got everything youll need.
Posted on: 2003/7/13 13:25
